JimmyS1969
MOODerator
I think I'll try disconnecting the hard drive from that controller and see if it works then.
Looks like the USB3 on my mobo is handled through two Etron EJ168 chips. Don't know if those have a reputation of being problematic, but it says something that they're separate chips (no special drivers for them either, at least not on the mobo support site). Newer hardware has USB3 built in the main chipset, right?
I think we may have a misunderstanding here. The driver for the USB controller isn't or wasn't my issue. But the driver for the interface had to be installed on a particular controller. In other words during the install, the interface had to be disconnected until the driver installer asked for it to be connected. Then the driver was installed on the controller it was plugged into. If I put the USB connection into a different usb port, it isn't recognized. Only the one it was installed with.
On the other hand, the inputs seem hot-hot-hot. Connecting my guitar I HAD to use the pad and keep the gain very low.
