spitzer
Greets
I've been looking for a small interface for my home computer, mainly to record electric guitar. So far I have on my list Steinberg UR22 mk2, Focusrite Scarlett 2i2 gen2, Presonus Audiobox USB 96 and... Behringer UMC202HD. They are in the same price range and externally (meaning "it looks like") they have everything I need.
All the reviews I've found have mostly covered things like the input preamps and such. However since I would ideally like for this interface to also replace my other (integrated and PCI) soundcards for all general use (LISTENING) I'm also interested in the outputs and especially the headphone jack, since I almost exclusively use headphones.
I've found specs for some of those interfaces but they are hard to interpret, some have the figures expressed with different names or in different units etc. For example I found a document that said the UR22 outputs 3.8 mW x 2 "nominal" and 6x2 "maximum" power from it's headphone output. What does that even mean? How can I figure out whether that is enough to drive my headphones? I need output power at least equal to my Asus Xonar (which is supposed to have some kind of an integrated headphone amp) that specifies an output power of 1 Vrms/3Vp-p with the hp impedance only being described as "optimized for 32-150 Ohm". From what I have tested by the way, the volume level is pretty much identical to that of the integrated Realtek 889. The headphones I currently mostly use are AKG K182s, I also have a pair of DT770s (80 Ohm).
With regard to the inputs I mainly just need a nice, clean signal. The Realtek is horrible, the Xonar is quite good for recording but there are other big problems with both of them, mainly the lack of direct monitoring. My larger setup not at home is built around an ADA8000 and the sound quality is plenty good enough for me so if the UMC202HD mic/line pre's are of similar quality, I would be happy with that. That small Behringer has more features than the others and who knows, maybe at some point I would realize I actually would have wanted those pad switches or something.
Thoughts? Recommendations? Which is the most stable, has the best drivers? Although again, emphasis on the headphone output power.
A few years ago a friend with no recording experience at all was looking for a simple recording solution for solo vocals and basically off the top of my hat I said get the Steinberg CI1 (completely based on the specs). Since I'm guessing the UR22 would be mostly similar, I've been wanting to borrow that CI1 for 15 minutes so I could test it myself but I can't reach that friend now.
I'm still going to use the ADA8000 anyway since I record a lot of drums and I need the channels. Like I said, I've had that ADA8000 for a long time, close to 15 years... back then it wasn't cheap either and there were no alternatives anywhere near that price range. Those were the days.
