C
CherylJosie
Member
I am mixing sound for a local band at their (infrequent) gigs.
The band is using the Mackie DL1608 mixer running Master Fader (actually an earlier version where the only available user manual is in the iPad app, but you get the idea) with SA1530z full range mains and SWA1801z subwoofers.
I plan on setting the downstream levels so that all instruments that use the subwoofers will be at 0dB on the aux fader because that keeps it mindlessly simple. I also plan on keeping the active speakers' input attenuators at 0dB because that also keeps it mindlessly simple.
The level balancing between mains and subs will happen only on the aux sub channel output fader that is ganged with the mains fader in a FOH master VCA.
I tried using the 120Hz 12dB/octave highpass in Master Fader to cross the active mains to the active subs at the subwoofers' built-in fixed frequency crossover, but two things happened. First, the guitars were not using the subwoofers, and they lost 80-120Hz frequency range. Second, the drummer who owns the equipment expressed his desire to keep using the mains full range because he feels he would get maximum power output (and I agree, with qualifications).
I worked up a compromise of a 6dB/octave 60Hz crossover implemented on the mains and subs output in highpass and lowpass filters tuned to 60Hz.
This should put approximately 3/4 of the power through the subwoofers at 30Hz, split the power evenly at 60Hz where the mains are near the LFE corner of their low frequency peak output, and put 3/4 of the power through the mains at 120Hz, except that at 120Hz the subwoofers will already be in their built-in crossover range and dropping out some as well as phase-shifted so there might be a dip in the combined response at 120Hz. The mains have a small peak between 105-130Hz though and that should help smooth out that range, with any residual frequency response aberrations fixed in the graphic.
There will be some vertical beaming due to the relative phase shift between drivers with a 6dB/octave crossover, but the mathematically summed signal of this 6dB/octave crossover is impulse-perfect and the imaging should be largely unaffected by some vertical beaming at such low frequencies, so I am fairly confident this solution will work out OK.
I have not tested this crossover configuration yet, but I have added it to Master Fader for the next gig.
I am new at this, and so far I have gotten little feedback as to the proper approach online. I had to come up with this solution on my own by reading manuals and applying my pre-existing electrical engineering skills.
Any suggestions?
Any suggestions?
