bouldersoundguy
100Hz was my preferred crossover frequency. It took enough out of the mains that they seemed happy with getting pushed hard, but didn't make the subs go too high.
And if you really want to get into things on that level, get SMAART and a reference mic, set the system up, and test it rather than guess.
I run a system exactly like this.
The front of house graphics on the full range: I slope the eq from about 100hz down to 0 at 20hz, you need to experiment with this both starting point and the shape of the curve some of the guys that use the system do a full cut from 100 hz down but I prefer a slope. If you do the old one two testing through a mic with the subs off it works for me, I hate reference mics, white noise and all that, you can tell if it's not right using your ears.
Then I have the subs set to a crossover point around 80 Hz.
I use a post fader Aux send to the subs (this by passes all the FOH EQ) I then balance the instruments going to the subs with the aux send. Usually Kick, Bass, Floor tom/low toms, sometimes Keys.
There is nothing below the 80hz (or even about 120hz) that guitars need to have, and especially vocals.
The full range set up like this sounds much cleaner as do the subs not having to filter out stuff they don't want via the crossover. Tell the drummer that doing it this way will actually get more power due to the system trying to reproduce frequencies in places they should not be, I.E 12" or 15" speakers trying to reproduce subs and subs trying to reproduce highs.
Alan.
The thing that smart systems do that you can't do by ear is fix the timing between the tops and subs. Once you do that, the system comes into focus and you don't have so many issues around the crossover frequency.
I was out of the live sound gig for a long time, when did everyone stop using proper crossovers? I still use a driverack for smaller systems. The big line arrays have a system to address each cabinet in the array, but that's a giant concert system.
Look like a good piece of gear. If the OP can afford it get something like this. If not do it like I said.
By the way is the original OP still reading this LOL
Alan.
I have a UMIK-1 and a notebook computer that I plan to install REW on. I have already tuned dual subwoofers in my home theater, so I know something about it.
Never used SMAART. Doubtful if there is any funding for it in this group, but I have used REW. In the plan, just not there yet.
Remember I am only talking about filtering the subs out of the full range, the full range part of the system is capable of receiving the sub frequencies, I just remove them to make the system cleaner and to let the full range run easier. The sub side already has a crossover. I am therefore using the graphic as a filter not a crossover.
I also forgot to mention that on my own system (as opposed to the in house system I use) my power amps have inbuilt adjustable crossovers. The in house I use most of the time does not have this which is why I use the graphic, some operators don't use the graphic filtering on the full range but that up to them, each to their own.
Alan.
By the way I hope we have not bamboozled the OP.
If vocal/guitar/etc. mics are adding too much rumble to the sound even when you high pass them
I would suggest setting the system up and testing it when you don't have a show to put on, especially if you can do it outdoors away from buildings.
The DL1608 has adjustable delay on the outputs, so I should be able to accomplish this, but it seems like too much work during setup. I need to do this offline unless the venue demands alternate subwoofer placement. We have one small bar that seems to want the subwoofers placed for modal response and I am working on a solution for that, including stands for the mains so the subs can move, but it is speculative at this point. That solution would require a timing measurement to do it right.
One nice thing about low frequencies, they're really forgiving about top vs. sub placement. Moving the subs a few feet either way isn't going to matter much given the wavelengths. What matters more is their placement relative to boundaries (walls and ceilings) and the other sub.
Since you're already thinking about this stuff, do some research on "power alley" and "cardioid subs".
Yes, the smaart system (and others like it) integrate the timing measurement.
You have a good handle on the science of speaker placement and the effects of crossovers, however you are missing the part about the speakers themselves having odd phase relationships to each other (even in an anechoic chamber). Moving the subs away from underneath the mains will make that a big issue.
Your mixer will be able to adjust the delays of the outputs, but you will need to do the measurement to have a hope in hell of getting it right.
That is the part I am not getting.
Why is electrically looping back through the sound card meaningful? Does that occur once, or once with every new timing measurement?
