Nola
how would you guys handle this situation
tracks of:
drums, bass, 1 guitar, vocal
do you just mix it mono?
tracks of:
There are a number of things you can try, but it depends on the type of song it is.
1. add a short room reverb to the guitar to give it a little spread
2. pan guitar a bit one way and pan the bass a bit the other, then add a bit of both to the reverb on the drums
3. stereo chorus
4. short delay (30-50ms) with the high end EQed down panned away from the guitar.
The first couple Van Halen albums only have one rhythm guitar track. Listen to those to get an idea.
Another approach is to actually record the guitar with a stereo mic configuration...like Blumlein Pair or M/S configuration.
If you record them stereo, can you still pan each mic's tracks l/r in the DAW?
Yeah that sounds interesting. I've never recorded stereo guitar, so it would be a learning curve, but it sounds like a good option for a situation like this. If you record them stereo, can you still pan each mic's tracks l/r in the DAW?
Any DAW that can't do that isn't worth the name.
thanks farview, those are good ideas, and i tried a few already, and found #4 the best so far. I'll try different combinations of what you mention.
when you say stereo chorus do you mean adding it after the fact or recording it with a chorus pedal and 2 mics?
i should mention the guitar is clean.
But I mean there's no weird anomaly where if you record in stereo and then pan it wider in the daw things break down.
Cool. So to me that sounds like the guitar is panned left but not hard left, then the snare/OH are more on the right. That's a pretty cool mix, actually.
Yeah, that whole album is a great reference on a 3 piece band mix. I wonder if they have some kind of ADT on the guitar just to widen it a bit. It's one guitar, but it takes up a lot of room.
In the live gigs...it sounded just as full.
If I recall, Johnny liked using a phase shifter pedal (or flanger) on stuff, which could fatten things up...but I don't hear it on this recording.
Here's the whole album if you want to skip through and get some ideas. Occasionally, there's a rythm guitar under the solos, but it's 90% just one guitar.
https://youtu.be/dzStP6vNk3Q
