i used to struggle learning modes,patterns e.t.c,had a great thirst for anything guitar .. used to sit and watch anybody play (still do when i get the chance) just to see where their fingers went
then one day i realized that their all the same thing ... after that i realized that i could take most scale books and rip out most pages
(suppose having the same "scale" repeated in every key is great for staring at while actually playing in that key
for those that don't know ...
(and im speaking of relative to today,guitarists and not "ye olde" interpretations of modes or history)
if you know 1 pattern block then you know 7 different "scales" its
impossible to know only 1, to get the other "scales" just change the root note
i.e:- if you record yourself
(on a phone or whatever) playing a C note then play a Cmajor scale over the top it sounds all "happy" ... if you then record a D note and play the
EXACT same Cmajor pattern in the
exact same place it sounds all bluesy
(its now D Dorian mode)
now do it with an E,F,G,A,B keeping that Cmajor pattern in the
exact same place ... that lil happy major scale is also death metal,rawk,weird,neoclassical,sad,tearful,lost,blues yada,yada ..
modes = a scale with the root note changed,that's it,no matter how complicated anybody makes it sound all you do is change 1 fecking note
thinking of it this way will save hours an hours of wasted work ...
btw id recommend learning the pattern blocks using 3 notes per string,this tidily makes 7 easier to learn patterns and after much practice the 3 notes per string will help you get great speeds up
(like it or not you WILL get faster
Major scale depersonalized and reduced to pattern blocks
