Steenamaroo
Hi folks.
I have, what should be, a simple question for you all.
I have two preamps here - different brands, both balanced TRS outputs.
I used TRS cables into a TS patchbay after the outputs today by mistake and realised the error very quickly, but....
One of the preamps carried on as normal with a little bit of audible buzz on the output.
The other had it's signal high passed to the hilt. This could be remedied by grounding the ring.
So to summarise, both balanced output preamps were sending signal on tip and sleeve with their rings left open (leave it!).
Had I used a TS cable by mistake, I probably would have had cause to notice as the rings would have been grounded.
Any ideas why one would have a healthy output regardless and the other would not?
It's not a big deal. I'm just curious to know.
If it helps, I know the high-passed sounding one has output transformers. The other does not.
Many thanks in advance.
