E
ecc83
Read something the other day that I "knew" but had not thought the circumstances through?
Problem: a chap having trouble sending an AI's line outputs, via transformers to a venue desk, cannot get much above -6dBu without distortion.
That problem seems to be due to the 'line' signals feeding mic inputs on the desk which have an input impedance of only 1 to 1.5k. Now, most line outputs would drive such a low Z but in this case, and with the transformers, apparently not. The suggested fix? Use DI step down transformers not 1:1 line jobs. It seems standard practice for stage feeds to always go into mic inputs?
However, feeding your common or garden DI from a line output is also fraught. This is because they use a TS jack and so a TS plug. If that goes into a TRS balanced AI line out then it will short the ring signal to sleeve and also cause distortion. New cables needed TS one end, TRS the other but ring not connected. Needless to say, TRS goes into AI!
