When I right click a channel fader, I get
Don't know why you would get a different box...
OK, you guys are getting me close to what I want to do. Mr' Clean's screen shot helped. I first had to go to Preferences and change the "Last output" to 3, and then go back to the channel output and assign the track to channel 3. So, now I don't hear the guitar track in the mix, which is good. But it's not getting to the amp, which is bad. But we're getting closer.![]()
Not being a dick, but did you wire up hardware output 3 to the amp?
Thanx man. I checked out the price of "Reamp" boxes. Holy shit! $200. I'm not spending that on something like that. From what I understand (and I might not understand), can I not just get a cheap Boss pedal, bypass it, and put it between my interface and amp? I'm getting a bit of noise, but really, it's less noise than I get from plugging my guitar and it's P90 pick-ups into my amp. The only noise I'm getting from doing this is a kind of swishy interference, but it's way lower than the actual guitar signal, so I'm not too worried about it.Glad you got it sorted man, I always re-amp as I record, everytime usually....That way, if my amp'd track sucks, I've still got the di, so I can re-amp it later with a better/different sound...
I had to buy a Radial RMP (about $100) because my interface had lots of noise & hum going directly into the amp, but since I got the re-amp box, problem solved...
I always set up 2 tracks to record at the same time, a di and an amp'd track...I always kill the master out on the di, so I don't hear it at all, what I hear is coming from my amp...you can ALT/CLICK the I/O button on any track in the mixer to kill the master output...But, since you've gotta set up a new hardware output, it's just as simple & easy to untick the master out when you add the new output...
Again, glad you got it sorted dude...
I know I'm late to the party,
but regarding impedance I found this video excellent:
You're right. The first one here is only $100. I like the 5th one from the top. $1400.I think there are passive boxes that are less than $200. You were probably looking at the Radial active unit with all the bells and whistles. There are a couple passive units out there that are around the price of a decent passive DI, which is essentially what it is. (a reamp unit will have a different transformer than a di, which is why running a di backwards doesn't always work very well)
But that video above is pretty good. He never quite gets to the real point - everything is a voltage divider - but he does a good job of describing what's happening. He's talking (almost) exclusively about the other end of the chain, though. That is actually the most important part of the process. You want to capture off of the guitar as close to what it would be doing going into the amp as possible. The passive guitar is kind of emo - overly sensitive to the conditions it finds in the outside world. Heavy loads (low impedances creating greater demands) cause it to get dark and mopey.There is no god damn impedance issue!
OK, I hope I'm not over-thinking this. But I recorded a sample of the noise that's coming out of my interface and going into my amp. This is with the amp cranked and ready to record. This "noise" comes in at -53db. I didn't alter the volume of it, as you can see if you check your meters.
Now, do I really need a box of any kind? -53db....the guitar signal drowns the hell out of this. At this volume, you can hear the guitar from across the street.
One thing for sure. I haven't checked the actual level in numbers, but the noise from the P-90's on my SG is WAY louder than this when I plug the guitar into my amp.
The Millenia is also a high end mic preamp with an EQ that happens to have reamping capabilities. Much more than you need for what you are doing.You're right. The first one here is only $100. I like the 5th one from the top. $1400.. But it comes with a ribbon mic.
reamp | B&H Photo Video
