I have a fender m-80 lo-250729 amp. went to play and none of the knobs change the sound, volume or input. Overdrive channel or reg. What happened and how do I fix it
Do you mean the amp produces no sound or you can't change the sound it now produces? If it does not light up or produce a "pop" at switch on check if there is a mains fuse blown. Should be one next to the mains power lead or if it uses an IEC mains conn' the socket might have a fuse in it.
Replace with EXACTLY THE SAME RATING. If that blows, tech time.
