jarl,
I didn't mean to come across as if you had a lack of knowledge of the gear.  I probably came off a little insulting!  Well, in my experience, I've noticed that even with my Millennia's it can sound sterile (clinical), but it really depends on the room.  The same goes with running the MK2's
straight into the UFX.  I completed some recordings and completely thought it was horrible from the sterileness - it could have been my playing or whatever....
I just remembered what also influences a recording.... Humidity!  I live in Minnesota and it has such a dramatic change in humidity levels throughout the year.  I record in a lot of churches and the relative humidity will drastically change reverb time and room resonance.  Even in all stone or cement buildings, the humidity drastically changes the sound.  What is worse is having two
sessions on different days and the humidity and temperature level changed between those times - it completely changes the sound of the musicians.  I always have them break up the pieces in a way that avoids using takes from different days on the same piece.  Also, I've gotten to the point where I make sure my clients let me know if they know the space enough for sound changes from the climate condition.  It helps decide what season to record in to get the best sound.
Almost everything I do is classical (and jazz), so it's mostly
acoustic instruments.  I wish I could hear what's going on with your gear.  I think my UFX is the first generation (2010ish), so maybe they've made some other changes since then (which they have with the external controller).
I've been really unhappy with most reverbs - especially with the "trebles being to dry" too.  This is a relatively inexpensive, but decent reverb that I've been using:
ValhallaRoom: $50 – ValhallaDSP  Is it perfect?  No, but I can get some realistic rooms out of it (which is so important to classical).  Maybe it would help with your trebles?  But than again, reverb shouldn't be used to fix a "bad" recording problem or as something normally done on every
session.
I just did a recording of the Associate Concert Master of the Minnesota Orchestra doing the complete Bach violin partitas and sonatas.  Every time I record a violin, it always has that initial screechiness going on until I find the right mic placement - even with a world-class musician.  After a couple days, his wife came in a I let her listen through a different set of headphones (Beyerdynamic 770s) and she hated the sound - lack of warmth and too much treble.  That made me think of how important good monitoring is.  I use the 770s for isolation, but my 880s are much more transparent and warmer.  At the same time, I've gotten used to all the different flaws of my gear and know how to work around it or to my advantage.  Maybe it's your monitoring system.  I haven't used the AKGs or the Spirit
Absolute Zeros before, so it just an idea.
I also used firewood spread across the marble floor to warm up the sound.  There was too much delay from the violin to the floor to the microphones causing a slight amount of phasing.  Using the wood to diffuse the sound more helped - and it absorbed the high frequencies a little.
I feel badly since it seems like we do basically the same thing and I wish I could tell you exactly what to do to get the sound you want out of your gear.
Maybe additional gear with a different sound would be good as Dave suggested.  I really like the John Hardy's - he even designed them with Schoeps in mind.
The John Hardy Co. Home  It may have "the preamp with some kind of sound warmer/distortion" tone you want.  I haven't used anything by Cranesong.
Maybe this gave some ideas?
