famous beagle
Thank you for the input. When I first purchased the At 2035 I also got a Behringer 'Tube Altragain, MIC100' mic preamp because it had phantom power. It boosted the gain so much that I couldn't seem, between the gain and output controls on the MIC100 and the controls on the 244, to get a level that was not either to low on or pegging the 244's VU meter in the red. I did engage the -10db pad on the 2035 and the limiter on the MIC100 and it help a little. That is when I found a phantom power box to use instead of the MIC100. Since external mic preamps are not covered in the 244 owners manual, I did not realize that the output of the MIC100 was a line-level signal, I will have to do some more playing with the MIC100 and see what I can do.
Again, thanks for the input.
Yes, when you run the external pre into the 244, turn the trim knob all the way to the "line" side. This way, you're essentially just setting the level with the external pre. After you get a good level on the Ultragain with its gain knob, start with the output all the way off and then raise it slowly until you get a good level on the 244. I haven't used the Ultragain before, so I'm not positive on how it works exactly. But if it's still too loud with the 244 turned all the way to "line" and the Behringer's output all the way off, then you can bring down the Behri's gain knob until you get a good level on the 244.
Considering all those options, you should definitely be able to get something useable.
