L
I would like to get pro results if possible but on a budget like most people.
Then mic everything you can. Each kick, each tom, two overheads, maybe the hats. Use a room mic only if the room sounds good. A lot of people swear by room mics, and a lot of people have shitty drum recordings. Room mics are dumb if your room sounds like shit, and most home recording rooms do.
Also, just a thought, it's not 1985 anymore. Does your drummer really need two kick drums? Does he really need all those toms? Is his name Nicko McBrain? It would be a lot easier to record with good results if he dialed his kit back a little.
Thanks for the advice. Your probably right he doesn't really need that big of a kit but he does use all of it and he sounds good.
Good advice I will run it by him.I'm sure he does. Just run it by him. If he's good he'll sound good with less and it will be way easier to record. One mic on one kick with a double pedal is easier to deal with than two mics on two kicks.
When a kit like this turns up at the studio my heart usually sinks. The kit could be half this size and the drummer should be fine with it, single kick with double pedal, 2 flying toms and 2 floor toms, and you are away.
Also the use of smaller tom sizes in the studio works well. Leave the big kit for the live gigs.
Oh to answer the question, if this kit turned up about 13 to 14 mics, sigh. Snare top and bottom, hats, 1 for each tom, 1 on each kick, and 2 overheads as minimum = 13.
Then when mixing half the mics will be turned off as the drummer won't play them all anyway, unfortunately the tom ring that will usually turn up with a kit like this will be in the overheads.
Alan.
Thank you everyone for the advice. I did talk to the drummer and he is willing to use a smaller kit for recording. He does use everything on the big kit when he plays though. Like suggested I will have him use a smaller kit for recording and he can use the big kit for live shows.
Hmm. IDK. I liked :28 -before they brought it back in. Sounded cool at first, but then kinda like adding a big verb- ok in solo but .. in a mix?Siegfried at Beach Road has "coined" the anal mic technique. haha. I know it's been done before in different ways, like a distant mic (further than "spot" mic and closer than "room" or "oh") near the kick/snare to be used for ambiance or what have you, but he says this specific mic position is a great ambient mic for smaller rooms that don't sound as great as a huge pro studio. So it's an alternative to room mic(s). In this example it appears he used a fig-8 mic mic pointed off-axis from the kick and snare, however I have seen him do it with a 57 pointing straight up at the throne.
Anal Mic In The Drum Mix - Siegfried Meier at Beach Road Studios with "Mouth" Recording "Brown" - YouTube
