cakewalkKaKed
HOORAY FOR BOOBIES !!!
love this thread
Thanks for spending the time to explain that for me. I went shopping for epoxy a few weeks ago when I was first experimenting with this. It seems in this world of instantaneous gratification that slow curing epoxies are getting hard to find. I assumed that the longer pot life would make it easier to do a clean application. I bought some that was listed as a 1 hour initial cure time. It was thick, but seemed to spread out smoothly. It worked well for filling a few deep imperfections that I used it for. They were indistinguishable when I was done. I'll play with it some more before I finish the guitar that I'm working on now. I'm fairly confident with most parts of the construction, but that all goes out the window when I start applying finish.muttley said:Goes on all right... It is supposed to have a cure time of three hours but with the temp here right now it was best left over night.
Thanks for spending the time to explain that for me. I went shopping for epoxy a few weeks ago when I was first experimenting with this. It seems in this world of instantaneous gratification that slow curing epoxies are getting hard to find. I assumed that the longer pot life would make it easier to do a clean application. I bought some that was listed as a 1 hour initial cure time. It was thick, but seemed to spread out smoothly. It worked well for filling a few deep imperfections that I used it for. They were indistinguishable when I was done. I'll play with it some more before I finish the guitar that I'm working on now. I'm fairly confident with most parts of the construction, but that all goes out the window when I start applying finish.![]()
The front has a wash coat of shellac on it to protect it but tomorrow it will get a sealer coat. After that nothing more until I have the thing together and the final routes and holes drilled.
Amazon.com: Pacer Z-Poxy Finishing Resin 12 oz: Toys & Games
Is this what you are talking about? I'll order some of that.
Thanks Again![]()
Thats the stuff.. A bottle that size will keep you going for about a dozen instruments. A toothpaste squeeze amount will cover pretty much a whole front or back surface or neck maybe.
I got the z-poxy today. I'll experiment with it this weekend. I'm excited that this might be the solution I'm looking for.
That's beautiful, Muttely.
I think there may be a bit if confusion, when you say about "a grand" are you talking British Pounds or US Dollars?
I can't imagine you producing custom gits at this level for ~$1000.
not this one for a grand and it would be sterling. A stock standard finish with less expensive timber would come in around 1.5K. Where did I say a grand? If I did that would be about what it cost in time and parts...I got add my bread and keep money...
well, whoever is the beneficiary of one of your handmade guitars is obviously very fortunate, indeed.
