That's cool dude, no hurry on my part either, I'd have to put a little $$$ aside for the T75 anyway, seems I'm always a broke fucker anymore....The $$$ I had saved up for the "big" amp, well, my parents needed some help last month & I wasn't about to turn 'em down ya know...But anyway, lemme know if/how/when, I'll be here....When you get ready to do this, pm me & I'll send you my cell # too so we can actually talk....Thanks Greg, if we do this, this'll help me out quite a bit (the T75 especially) & may save you about $100 or so....The T75 is 16 ohms, right????
Since I'm here, I've read the debate on 8 vs. 16 ohm tone difference, do you personally think there is one??? I wouldn't think so myself, but don't know from experience....
A buddy is supposed to send me another Duncan Custom Custom, but with some different magnets to try in the strat, so maybe all these "little" things will keep me at bay for a while...![]()
Yes, the G12T-75 will be 16 ohm. The V30 will be 8 ohm. If you use two separate 1x12 cabs for your 8 ohm Greenback and my 8 ohm V30 you'll have to wire up the cabs to be daisy chained in series to be a 16 ohm load since you have only one speaker output on the head. You'll only be able to use the T75 by itself.
No, I don't think there is any tonal difference between 8 or 16 ohm as long as the amp sees what it's expecting to see. An amp set to 8 ohm that sees an 8 ohm speaker load will sound the same as an amp set to 16 ohm seeing a 16 ohm load. Solid state output sections are different, like they'll be louder with a lower speaker load, but with tube amps, the way I described is usually how it is in my experience. I don't know the technical specifics or electrical theory behind it, I just know what I hear personally. I hear no difference. I ran my JMP through an 8 ohm V30 4x12 the other day. It didn't sound really any different than my 16 ohm V30 2x12 besides one being a 4x12 and one being a 2x12. Even then the general tone was the same.
