N
nomadbyfate
When is the last time you used a table saw?![]()
your designs are pretty impressive
If my $10K estimate was wrong, what would be a more accurate one?
Let me ask you a direct question. Are you here to learn how to enclose this space in regards to a studio? Or is someone else going to do that part first?
i am trying to figure out what would be the best option for a mixing room within those constraints, before we enclose those walls.
so i still have the option to decide what width and length the room would be.
Given the whole job is DIY, and the chosen sheetgoods finish or substrate material, the total price of the required number of sheets plus finish costs would be fairly accurate ..for the diffuser end of things at least. For instance, you could machine the parts from plain MDF and finish to taste post assembly, fairly cheaply. On the other hand, machining from solid Pearwood would easily approach your estimate.![]()
http://www.myroom-acoustics.com/hosted/myroom-acoustics/MyRoom_Design-white_paper.pdf
However, if one wants to see a design which truly staggers the mind in terms of woodwork, budget notwithstanding..take a look at Blackbird Studios...
9 TONS of MDF, CNC machined and assembled by virtue of a proprietary mathematical sequence developed by George Massenberg.
View attachment 83594View attachment 83595
This redefines the word..sawdust.![]()
Oh, well then, you need to visit John Brandt's site and download the Mode calculator. This will tell you the best ratio of room dimensions that will fit.
He's also a member here, and may pop in to help too. He's one of the best studio designers in the world.
JH Brandt - Recording Studio Design and Acoustic Consulting
ahh yes mr Brandt's website: a lot of information
Just remember, it's the finished size of the room that matters. Not the envelope interior. That is..if you are planning on building a Room within a room. Which, from the looks of it, you'll have to do just to get insulation up. Of course, you haven't told us anything about your intent yet. Try to answer those questions I gave you. Btw, what are you planning on doing about HVAC? One more thing..where are you?
Wow, a room with a view, too bad its not easy to incorporate the view into the design, would be inspiring for song writing.
Years ago I did a session in the United Artists Tower in Nashville, the round building. Anyway the studio was on one of the top floors and had an awesome view. At night it looked like you were looking down at the stars. Songwriters really loved the place because of the creative vibe it brought out in them.
Cool project you have there, best of luck with it!
Wave,
That wouldn't happen to be Gene's old place with the MCI JH-536, would it? (Gene Breeden)
Cheers,
John
the space is actually the basement of a building which is under construction. the total length of this space is over 70': half for parking i.e about 32'. and the other half, we plan to divide into two parts: a jam room(about 11.5'). this is going to be isolated/ soundproofed. and a mixing room(we're left with about 22' here minus the restroom) the ceiling has already been built. and so is one of the side wall: this is a reinforced concrete running along the length of the space which also doubles as a retaining wall.
the width of the space is 16.4'(so the width cannot be more than this, it could be less since the other side wall hasn't been built) since the width is just 5m, if we were to use that as its length, wouldn't the room volume be too small? if this is an option plz suggest. i think this might avoid the problem of two different side walls(in which case: we could have two side walls made of bricks) and use the concrete wall as a rear wall.
also, the biggest constraint of all is probably the height: 8' from floor to ceiling and 7' under the tie beam/column.
this makes it pretty hard to get a width and length big enough to fulfill the 2500cu.ft criteria using the ratios.
i came across this set of dimensions: (8,15.20,21.12)' it doesnt fulfill the ratio criteria, also the width is almost twice the height. but it is more than 2500cu.ft.
plz tell me what you think?
could the boundary surface be of the same material even though the walls themselves are of different thicknesses and materials?? (the concrete wall is
atleast 3 to 4 times the width of a brick) ... please suggest other dimensions with better frequency response within those constraints. here where i am from, we don't have the concept of drywall, i don't know if bricks are better or worse.
most of the studios i have seen have very small control rooms and huge live rooms. how is this possible? shouldnt the main focus of volume be on control rooms?
i havent thought about where to place doors and windows. maybe somewhere in the front wall??
you mentioned about orienting listening position: what does this mean? arent the speakers supposed to fire down the length of the room?
let's see, about myself. i am a musician. i play guitars and drums. and i record demos on my laptop using cubase. i am using a line6 hd 500 as interface.
i am planning to get professional studio monitors once i move in to the new place.
and later on getting a mixer. for the acoustic treatment, i think we are going to add them a few at a time not everything at once depending on financial conditions. i hope it works
that way too. i am just starting out actually but if things work out maybe turn it into a professional studio. which is why it is so important that i get the room dimensions right.
sorry if i could not make things clearer, my english is not very good.
