M
Muffin
I've been having an issue with this for live settings. Basically I'm running Cubase 5 on a laptop with a Presonus VSL44. I use this live so I can play 4 separate tracks simultaneously. It all runs fine, but there will be moments while playing that all the audio cuts out. The song doesn't freeze, it continues playing but you just can't hear the audio for anywhere from 3 to 15 seconds(on average) and then it cuts back in. All 4 tracks were exported MP3's with their effects already set. So there are no VST plugins running while playback.
I've read that this is a buffer issue, however I can't find how to set it(or what it should be set to). I'm also assuming the settings will have to be set under the driver I use(which is the AudioBox Asio Driver).
Is this a buffer size issue? Are there other settings that could possibly be causing this? Thanks.
