P
Pahtcub
Also what room are you mixing in? Has it been acoustically treated? If not I wouldn't bother trying to get good bass/kick mixes. It's so hard to mix in a bad room and have it translate well.
Getting a little creative with it (damn I'm good)
https://dl.dropboxusercontent.com/u/19229896/Know it all 4.wav
Fixed the issues you stated except the bass, I don't know what you're talking about and can't hear what you're talking about. Took the liberty to correct a few pitch issues as well as stretch the end (BTW ALWAYS let your guitars ring out!! ALWAYS!!!)
https://dl.dropboxusercontent.com/u/19229896/Know it all 3.wav
What interface are you using? You should be monitoring straight from your interface for no latency.
It seems kinda pointless to mix a lot more since most of these tracks have clicks all throughout.
Always post everything you have recorded and let the engineer decide what he wants but yes doubled guitars panned hard left and right sound huge!
Also if you program anything please include midi track as mixing a prerecord we drum sample is pointless if you can very easily replace it with a decent sounding one.
So what I thought were overheads were the remaining drum tracks mixed together?
you can usually spot a rookie by how much they over use reverb on vocals. Also when you use reverb on vocals you need to filter the output of the reverb as you don't want reverb coming through on the high end.
