Proud new owner!
  • Thread starter Thread starter famous beagle
famous beagle
famous beagle
After about 4 years of waiting, I'm finally the proud owner of a shiny Tascam 246 in amazing condition. This thing looks basically like new, and the heads look brand new. I haven't had a look inside at the belts yet, but I've already ordered replacements for the capstan belt, control belt, and idler tires. So here's hoping to many years of 246 bliss! :)
Awesome! I picked one up a couple of months ago that this guy said was busted. All I needed to do was replace the belts and it works great! That 246 looks super clean. Have a fun! These machines are sweet.
The 246 is a great unit, and...
very clean!
:spank::eek:;)
Nice! Looks as good as the one I've owned since new! Happy recording!
Thanks everyone for the comments.
Umm ... first chink in the armor: I was getting ready to put it through its paces today and was stopped short. The head assembly seems to be stuck in the play/record position, so I can't even insert a tape!
I haven't opened it up yet. Before I decide whether or not I want to try and repair it, I'll fully test out the mixer section.
But I was just wondering if anyone had any experience with this symptom on a deck before.
Thanks!
Yes,...
It is the control belt that is responsible for deploying & retracting the head. It's a little square shaped belt, in your case that might be loose, slipping, or given up the ghost. It's an easy fix if you remove the bottom panel. Refit the old one, determine why it's slipping or replace it altogether.
:spank::eek:;)
:spank::eek:;)
Awesome! Thanks for the tip! I have a new control belt (and capstan belt) already in the waiting, so I'll take a look tonight and see if I can spot the issue. Fingers crossed! :)
Update: Well I removed the back cover last night. The control belt was completely broken and just wrapped around the small post, and the capstan belt was so loose and stretched out that it was just flopping around. And this guy told me that he'd check all the transport controls!
The good news: All the mixer functions work perfectly, and he refunded me $50 to cover the cost of new belts and idler tires. Now I just have to install the belts and check the record/playback/erase functions. Hopefully they'll all be good and I can call it a day. I really don't want to have to ship this thing back!
Hey Dave: Regarding the installation of the new control belt, does it need to be aligned with regards to the squareness of the belt? In other words, does it need to be orientated around the pulleys the same way it sits on a table for instance, or is it ok if it has a few twists in it?
Also, regarding the capstan belt, I found your excellent thread here:
https://homerecording.com/bbs/general-discussions/analog-only/tascam-246-break-fix-263547/
And I can see clearly the two screws that you removed, but what about the plastic white screw in the middle with adhesive on it? That one doesn't need to come off? I thought it was holding the flywheel on. No?
Thanks!
No, for the capstan belt, you'd remove the two small brass screws, then slip the belt under the bracket and also under that nylon keeper screw that rides on the center of the flywheel. Don't touch or adjust the center screw.
The control belt will align in a v-cut or diamond orientation, and it's best not to have any twists in it. Fortunately, when the belt is proper and power is activated, the head stack will locate to it's 0 position automatically.
You should be ok electronically & recording/playback-wise. The rubber parts are what goes on these things for the most part. Unless the circuits were overloaded and abused, there should be no problem. It's a great design that still stands above most of the other 4-track Portastudios.
:spank::eek:;)
:spank::eek:;)
Ok great, thanks for the info! I'm hoping to get this done this evening. :)
Ot...
As you guys may know, I've been selling a lot of stuff to make ends meet. As my gear storage goes deep, it's been quite a nice alternative for me. Not only do I need the extra money, but it's been a good way to simplify my life, as well as moving some unused equipment onto someone who's really going to use it. I've gone thru several of the recorders so far, and the buyers have been uniformly happy.
Anyway, I've sold (2) M30 mixers so far, (as well as a whole variety of stuff), and I have 1 more M30 to sell, while I'll keep the last one for myself. One M30 mixer I knew was in a large flight case in a stack of stuff in the garage. A very large and heavy case it was. When I dug it out of the stack, turned it over and opened it up,... YEAH! Sandwiched into the case upon foam was a very clean and minty 244! Don't ask me how I must have forgotten it was in there!
The quick version of the story (?) is that I tested the capstan & hub motors without a tape, by depressing the cassette-in microswitch. All seemed well. By the time I located a tape to test the unit, the Play motion had ceased and the capstan had stopped. Fortunately, I had an 11.7" flat belt in a bin in the garage, so I replaced it. The original belt was extremely stretched out and flaccid. It apparently had just enough rotations left in it for that quick spin test, before it simply slipped down and off... faster than my pants on a Friday night! OMG, I just had to say that! How often do you get to use that line?
After a quick replacement of the main belt, the hidden 244 from the mystery case tested out completely. I was very pleased! Not only is it a great unit to do recordings on as the mood strikes, but if I feel in a pinch I know I can turn it over for at least $150, if it really comes down to it. The buttons are slightly yellowed, but it's in really good condition and tested great! I like happy, fortunate suprises like that.
Mental note that I have to find a source of a few new belts for my various fixit gear, of which there's many! I fix things as I go along, and mostly by necessity, but the fairly good cache of belts I had is depleted. I was getting them at a place called Electronic City in Burbank, and some at Fry's Electronics, but I've not been to either place in years. I hope they still have belts, if at all, this late in the game! I'd hate to have to go to eBay to pay scalper's prices on belts, just caus some other techy guy bought a big stash of stuff and I didn't! (but I will do whatever I need to do to fix this gear, on & on!) Belts used to be fairly common and easy to find. I'm not sure about that anymore.
Found-old-gear is like having new gear!
:spank::eek:;)
For my money,...
those 80s vintage Tascams were some of the best consoles around, large or small! There are too many good ones to choose from!
The 244 has the bomb of a little mixer section for a 4-tracker. The 246, even better! Much 4-tracking fun and good recordings in the box!
YMMV:spank::eek:;)
Beagle, congrats. 246 remains my favorite 4-track Portastudio of any brand. Yours looks...REALLY nice.
