B
BriGreentea
Couple of things (adobe audition). Keeping the mulititrack in the -6 to -3 range I've been making tests of cd's on my mixdowns doing different things. I've been importing a mild use of a multiband compressor which helps clarity, hiss reduction, messing around with the channel mixer and the stereo maxing setting and the mastering section that consists of elements of shelving and peaking the eq, studio reverb, widener, exciter. Also has a strange setting of a "loudness maximizer" which to me is not much different then using the boost part of the limiter. I also learned with this much more then 10-15% doesn't sound very good and get distortion. From there the last step would be the hard limiter setting it to -.01 with the boost at 6 db. I tried messing with the boost getting it past 6 and then come into the distortion part again.
My goal is to get the cd as loud as possible without clipping or distortion but is decent but I don't understand what tricks are there to make the final product fairly loud. The only way I figured out is getting the boost input louder but then the waveform looks like a brick and sounds more distorted.
Then the final thing is I've seen many people on mastering do the limiter last before saving the file. So for the hell of it I tried the limiter second to last then tried the mastering function last. Sounded good, then compared sounds to my previous saved file. Seems like it sounds louder and better but I haven't saved it into a cd to make that type of determination.
Another thing I haven't tried was someone said to normalize the file to -3 then limit. Does anyone do this?
