*working up the page to respond*
yeah, i've been tempted but have always though that for the price i'd rather get one or two little bits of "real" outboard (i do love the tactile element of real knobs). A friend of mine uses one and swears by it but he's also got a lot of cool outboard so i don't know how much he really uses it.
the "if i had better plugins" question hits everyone working with a DAW at some point and the answer is often yes and no. it's not going to instantly make you mixes better but it does open up more or different available tools to get the job done. With some mixes (mainly the ones that need almost
salvaging!) i quite like using the stock logic ones to start with as they cover a lot of bases and i'm fairly competent with them and, once i'm at a point where things start to sound balanced/cleaner etc i may swap one or two plugs for third party ones for "flavour". If i'm working on something that was recorded well and pretty much falls togther i usually just go straight for the plugins i
know will work. As i've said before, i try not to think of other plugins as better or worse than logic's stock ones, but purely as extra tools for the job
Also, as i said, a lot of plugins nowadays have a trial period with no limitations to the plugin (some do, which sucks) so it's always worth trying stuff and seeing how it goes, although it's usually best to wait until you know you've got the time to try them
I'm a sucker for most things focusrite and can't stop singing the praises of their Midnight suite plugins; one EQ and one Compressor for £79 (works out at £39.50 a plugin, that's CHEAP!). In the higher end, the waves plugs obviously get a lot of praise but the packs are fairly pricey. I'm still really digging the DDMF 6144 eq (based on the Portico 5033 EQ).
For that tactile element (and in an attempt to get a better sound) i bought the FMR RNC, an ISA220 (which
wasn't cheap but soooooooooo worth it), an Alesis Microverb (the original one) and a friend DIY'd me a sonic maximizer clone, and i'm now looking for a stereo EQ for my rack and the RNLA. A lot of the time i stay ITB, but for some things i run them OTB for some processing and record them back in. Could i get the same sound just ITB; probably, but whether it's all in my head or not, the stuff i run through the outboard sounds more 3D to my ears and because i'm forced to use my ears when OTB rather than looking at EQ's in logic the results are often better.
yep, i did see the other drum buss but assumed it was the kinda "fake drum room" effect. The limiter thing is more just my preference i suppose as there's no right or wrong way to do anything musical. I sometimes sling them on kicks and snare if the compressor doesn't do the job (or is there, as you said, just to balance), and i agree that it does give that big, punchy, in yo' face drum sound but it was more the limiter on the vocals that got me.
tbh, the extra menu on the logic compressor (and some of the other stock plugins) is one of logics best kept secrets. I only found out about it by accident on a forum somewhere and it changed my view/usability of alot of the stock logic plugins. the "wet/dry" mix and "output distortion" options as well as the different circuit types on the logic compressor really opened up a whole new world of flavours.
meh, if you are a n00b (which i don't think you are, especially by the standards of regular n00bs) you have a solid understanding of what you're doing, why you're doing it, and a desire to learn how to do it better. I'm sure we're all n00bs in some aspects of HR. hell, as HR's we tend to be jack-of-all-trades in the studio because we have to be and thats
A LOT to learn. My n00bish area is mastering
