Gekko, I agree,
It's also important to see things in their historical context.
CD's came out around 1982. mp3's didnt appear until the 1990's
because the software hadnt been developed until then.
mp3's were never meant to be the equal of CD's and uncompressed in general, in terms of sound quality, let alone some sort of improvement. mp3's were a convenient trade off and always will be.
To suggest that CD's were some sort of high point and then it all started going downhill when mp3's arrived is to misunderstand the history and the reason for developing the technology in the first place.
Also, as mentioned earlier, a lossy audio format such as mp3 is a bit like analog tape formats. With analog tape you can use wide tracks, and fast speeds for good quality audio, or you can use narrow tracks and slow speeds where quality doesnt matter that much. In the same way, an mp3 can very mildly data compress, with little or no audible degradation, to heavily data compressed, with massive loss of audio quality, but perhaps useable for the purpose in mind. And everything in between.
It also depends on the quality the original material being compressed. You "cut your cloth to suit the garment".
Yes, a Type II cassette using Dolby B (properly set up and executed) can give very good audio playback of a finished music production. I would happily listen to music all day long on such a format.
I should know. I own three Nakamichi cassette decks, all personally maintained and working well. One (LX1) is on a small table next to my bed where I can listen through good quality AKG headphones to my big collection of cassettes. Been doing it for years. Two out of my three Naks have user adjustable play head azimuth (a modification I designed and installed) so that I can maximise playback quality and minimize Dolby tracking errors.
I also have three
Tascam 122 MkIII machines, ex some analog recording studios which I used to maintain.
Even an uncompressed file such as a wav or AIFF can be made to sound worse than the cassette (by using a mere 22.05khz or lower sample rate), but what does that prove?
mp3 is not a fixed audio quality. It can be tailored to whatever quality trade off you want.
In any case, these days, people can use much higher mp3 bitrates than they used to because of improvements in software, network speeds, players, flash memory capacity etc. What might have been an audio quality constraint 15 years ago no longer is.
In 2012 should we even be having this discussion? Oh well, the good thing is people will end up learning, which is the whole point of a forum like this, so it's a worthwhile discussion ultimately.
