Chris F
I'm trying to run a pair of external mics - in this case MXL 603s - into the mic input of a Canon Vixia HF M300 video recorder recording instructional double bass videos. Since the 603s are condenser mics, I'm running them through an M-Audio DMP3 and then sending an 1/8" stereo feed from the output of the DMP3 to the camcorder. It sounds fine for the voice part, but distorts every time I play the bass. I had this same distortion issue when sending the same mic signal in the same way to an Edirol R-09 audio recorder and plugging into the "mic" input, but was able to solve it by plugging into the "Line" input on the R-09 instead. The problem is, the Vixia video recorder doesn't have a "Line" input, and no matter how low I set the "mic input" controls, I still get distortion.
So it seems I must be sending a line level signal to a device not equipped for it. My question, then, is how to convert this signal (these mics and preamp sound great for my needs when recording audio into the R-09) into one that I can feed to the camera to eliminate the distortion? I have a cheap mixer (Alesis iMultimix 9R) to work with if that could be part of the solution. Thanks in advance!
