RecordingMaster
A Sarcastic Statement
Hi there,
I have maple drums with wood hops which increases resonance of the drum. The floor toms sit in cradles as opposed to being RIMS mounted or attaching legs or brackets to the actual shell. This increases resonance yet again.
When I used to record with my old kit with metal hoops and legs attached to shell, due to a lack of mic stands, I used to use mic clips on the floor toms with mics that are supposedly equipped with an iso-mount. I've never had a problem before, so I went and used them on my new kit to record a series of songs for an EP. Without listening too carefully to the floor tom tracks, I went ahead and kept those tracks because they sounded great as a whole.
So now I am in the mixing stage adding a couple subtle gates to remove some bleed, compression, eq, verb etc to each drum track. When I zone in on the floor toms (I have 2) I am hearing a low rumble that is constant the whole time, even when the floor tom is not being struck. The kick drum bleed amplifies this as well. I tried fixing it with a gate, but when the gate closes, it's too abrupt - it doesn't trail off. It just ends. So its "Drum hit">"Natural Drum Resonance">"Vibration problem">"Stop". It doesn't gradually fade it closed. I've tried experimenting and can't find a way to do this with the gate that comes with Pro Tools 9 under dynamics.
Is there another way I can get rid of this constant hum/rumble on the 2 floor tom tracks? I was wondering about some sort of frequency noise filter (not just a parametric eq) that can zone in on the issue and remove or reduce it.
Any help is greatly appreciated, as always. Thanks guys n' gals.
