mixguy
Well, do you, punk?
You can always get a warm cup of coffee and see if this helps LOL! This is totally a personal preference. If you would like to share a sample I would be glad to give you my opinion on the sound of the recording quality.
...use a tube preamp, or export tracks to your computer and use a DAW.
Firstly, the OP, by asking how to get a warm analog sound from a digital recorder, has already opened that door because implicit in the question is the assumption/assertion that there is a difference between analog and digital. Otherwise the question makes no sense. The OP also implies that analog is better because they are seeking to change one medium into another, hardly something you'd do if you thought analog was worse.Here we go. Already with the analog vs digital.
That's precisely what I was doing by suggesting the OP change the way they listen. It wasn't a flippant remark.You know this is all good fun and all.
But.. rather than pointing out that maybe, just maybe there's 9 other things with hugely more impact, and importance.. to making really good music and recordings?
how to get a warm, analog sound from a digital recorder?
Cool. I did missread you then. My bad. I was sort of taking it from yours and Gecko's together.Firstly, the OP, by asking how to get a warm analog sound from a digital recorder, has already opened that door because implicit in the question is the assumption/assertion that there is a difference between analog and digital. Otherwise the question makes no sense. The OP also implies that analog is better because they are seeking to change one medium into another, hardly something you'd do if you thought analog was worse.
I remember when I switched from an analog 8 track portastudio to a standalone DAW. I was expecting this brittle, pristine, clean, sterile sort of sound and I received quite a surprize when I discovered that my recordings were just as thick and soupy on the Akai as they were on the Tascam 8 track. I honestly couldn't tell the difference. The only time I could was when one of my drummer friends pounded the drums into submission and I had the levels too high and the drums constantly clipped and the resulting CCCCRRRRR sound was so awful, I never went there again.
Perhaps instead of constantly focusing on "I hate this, this is digital", by changing the way one listens, the focus can shift to "how can I make this sound how I want it to".
I've heard digitally recorded stuff that sounds 'warm' or 'pleasingly dull'. I've heard analog recorded stuff that sounds 'clean', 'spiky' and 'harsh'.
Many of us that listen to CDs and MP3s when our ears were tape and vinyl schooled all those years have possibly had to change the way we listen. In fact, by simply recording music, when you listen for pleasure you find that somewhere along the line you've changed the way you listen.
I said it on the analog board thread . . . slam an output transformer hard and it will do pretty much the same thing as tape to the lows/low-mids (this is the thought behind wheelie's GAP recommendation, although the potential long-term reliability of that box scares me a little).
As for the highs, that varies quite widely according to the deck (as do the lows); I am hoping that we'll see some test results from various decks to get a handle on that. Clearly the HF rolloff is quite variable and the best decks (good 1/2", 2") have slim to no rolloff, but it's whatever you were accustomed to. I don't think there is a single tape HF sound. HF distortion I don't know yet.
Anyway, you can use digital emulators for wherever you want to go, but you can probably also use real analog but non-tape circuits to accomplish pretty much the same thing. Whatever floats your boat . . .
Unfortunately, since he is using a $250 studio in a box, I doubt he will pop for a reel to reel anytime soon. Especially since a reel of tape will cost almost as much as the entire recording setup he is using now.You can get good results with the most humble Tascam or Fostex half-track reel-to-reel like the Tascam 22-2, 32, Fostex Model 20, E-2, or an Otari MX5050, MX50, MX55. Mixing down to analog can have a huge positive impact on your sound. Perhaps the best investment you can make short of tracking with analog in the first place. Good luck!
Just curious, what makes you scared of the long term reliability of the GAP? I'm a very amateur preamp builder, and just want to know what you see in it.
I recently upgraded from a Tascam MF-P01 to a Tascam Dp-008 digital recorder. The DP008 sounds great but flat... and dull.
I cant go back to my mfp01 because it no longer works.
THe only other cassette recorder I have is a Sony TC-WE475 dual tape deck.
Is there any way I can recreate the analog sound on the dp008 by bouncing the mastered mixes to the tape deck? or will it make no difference?
what are some other ways i can get that sound?
This is the only gear i have.
Take it from the motion picture industry...they capture images with 35mm film for the grain, density, "forgiveness," beauty, warmth, etc....and immediately transfer to digital for all that follows.
I pretty much try to avoid solid state as much as possible because....
