My chain goes and settings were as follows, I run the ignite ts-999 with gain at about 9 oclock, volume left alone, and turn up the tone to about two oclock. Then place the nrr-1 in after, I run the lead tone gain at about 2 oclock, bass at around 2 oclock, mids at around 10 oclock, treble at about 10 oclock. Double track and pan left and right 75 percent, high pass at around 100 hz and low pass at around 10 khz. I use sonar's impulse loader, but you can use either kefir or lecab no problems. I put the hi/low pass filters post effects, so you can use an eq after lecab or kefir. Just play with impulses, perfect space in sonar allows me to scroll through my giant list of impulses to get the one I wanna use, which is pretty helpful. I believe that I used the Mesa os 4 cab impulse in the sperimental pack. If that helps, tone also depends on guitar, pickups and such, I used a sterling by music man jp100d for that sample, the strings needed changed so the tone was a bit tinny if you wanna call it that, but it won't if you have a good set of strings. Hope this helps ya, post us a sample of how things go for ya.
