famous beagle
Ok, so this may seem like a newbie question, but it's been something that's bugged me for a while.
Let's say you're recording a vocal with a condenser, and want to compress it a bit as you're going to the recorder. You're using an outboard mic pre and outboard compressor (they're separate pieces of gear).
What's the typical recording chain?
I always figured you'd go into the pre first, then out the pre into the compressor, then out the compressor into the mixer or recorder. Alternatively, you could go in the pre, out and into the mixer, then in and out of the comp through the insert, then into the recorder. As far as I can tell, that's basically the same thing.
However, in reading a book by Peter McIan, he says (when compressing a vocal to tape) to plug the mic directly into the compressor first, then go into the mixer. (In his example, there's not an external pre referenced; the mixer's pre is used.) This guy produced and engineered some big bands in the eighties, including Men At Work, so I'm assuming he knows what he's doing. But I've never tried it this way.
Is this the more common method for compressing to tape? Mic --> comp ---> pre ---> recorder?
And: If you do this---i.e., run in and out of the compressor before going to the pre (which is supplying phantom power)---will the condenser mic still work?
Thanks!
Thanks!
