a bit off topic i know....
I plan to record to tape, mix down in to computer. I've been doing this with my 488.
problems I've had...
Latency! If I record each track separately into the computer, I have such a hard time, lining up the tracks to make timing like it should. Even if it's a mille second off, it can ruin a song. So to avoid this, I record all tracks at the same time, and end up having to perform 'live mixing'. Not convenient when using effects, especially as there are only 2 effect sends on the 488. Anyway to the point...to avoid having to dump tracks into the comp..I've been looking at 16 tracks (8 tracks aren't enough, and bouncing confuses me).
Is there any knowledge or technique I missing out on, regarding...mixing with effects....dumping tracks into comp? I'd prefer an 8 track recorder, they're much easier to find.
thank you
