Wish
Never Sarcastic....Honest
So...you want to make decisions about mic placement through drum isolation headphones while you play???
That's a bit tough.
Just banging on an individual drum and moving the mic around to find the best place for the mic....can you position a mic without hitting a drum?
Either someone ELSE has to listen through the monitors and come adjust mics while YOU play...or it's the other approach that you don't want to hear about. You doing it yourself.
Yeah...it's just me.
Look...the first couple of times it's a PITA...play, stop, listen to track, adjust mics...repeat...etc...
...but once you LEARN what the different positions and different mics do...after that you'll be able to set up mics pretty easy on the first try.
You gotta go through the trail-by-error process to find out what the different moves do in your space with your kit and your playing and your music...etc...you gotta learn for yourself.
Try and error. Yeah...that's the real problem right there.
I've got other things to do.
