J
J_R
I have a Behringer Europower PMP3000 16 channel powered mixer.
I just got a 16 IN-XLR x 4 OUT-TRS x 100' Live Wire snake.
Now the fun begins and the confusion starts.
Things I have figured out: (feel free to correct me please)
1. I'm not sending the power driving the PA back via the snake. I have 2 separate neutrik cables for that.
2. The TRS returns are for the signal to the monitor system. Period. That gets amplified downstream.
3. The board only has 8 XLR-in connectors - the remaining connectors are all either TS or RCA. Therefore to connect them I need 8 XLR-F Lo-Z/Hi-Z RS-M transformers with pigtails. (The connectors are too dense so pigtail leads appear to be essentail)
4. Having only 8 XLR connectors means only 8 mics get phantom power - so I need to be mindful of what I plug in where
Big Question: If I want to plug in a Hi-Z device to the box-end of the snake (For example a Shure Green Bullet hamonica mic) - do I need another transformer, this time Hi-Z TS-F/Lo-Z XLR-M to plug into it?
i.e. Hi-Z device (TS-M)->(TS-F) Hi-Z/Lo-Z transformer (XLR-M)->(XLR-F) snake (XLR-M)->(XLR-F) Lo-Z/Ho-Z transformer (TS-M)->(TS-F) Mixing board
I have to ask because it seems that there are simple TS-F/XLR-M adapters available that don't seem to mention a transformer. What is the difference & where is it actually appropriate to use each?
I find myself shelling out for cables & adapters at least 50% the cost of the snake just to hook it up properly... I need to get it Right.
"Beware the hobby that feeds" - Benjamin Franklin
Thanks,
- Jon Rohr
Thanks,
- Jon Rohr
This is just going to be a Lesson for a while...
