Interface Problem need help!
  • Thread starter Thread starter PDP
PDP
PDP
There once was a note
I've had an M-Audio 2496 for 3 months. Recently it started getting a fuzz when recording audio. It goes away for about a miniute if you switch the buffer setting, but always comes back. I've tried both channels, un-installed and re-installed the driver. Could the card be bad? Works for a miniute clear then no good. Anyone know this problem?
Only when recording?
Check all your cables and sources.
What is your recording source? Mic, Mic Pre, Guitar, Etc.?
'Is the card bad' is a question for tech support. I'm sure it's under warranty and they have some trouble shooting routine to determine whether it is operating correctly or not.
Prado
Hi.Done your DCP latency test ? Have you added any other apps or peripherals in that time ?
