im having trouble using it as an audio interface with cubase le4. The interface shows sound is going into it ( level lights going up and down) but i can get no volume from it or onto a track thats recording.
In the device setup window select vst audio system and then pick your device in the "ASIO Driver" dropdown.
Then in the device menu select "VST Connections"
In the VST COnnections window set up your inputs and outputs.
Then on the tracks you want to record to you have to select which input you want to use. Click the monitor button on the tracks to see the input levels.
