Setting up Zoom R16 with cubase le4?
  • Thread starter Thread starter phlopip
P
phlopip
Can someone help me set up my Zoom R16 with cubase LE4. I have got the latest drivers etc. I just need a step by step guide if anyone can help.
Try being a little more specific. What are you having trouble with?
im having trouble using it as an audio interface with cubase le4. The interface shows sound is going into it ( level lights going up and down) but i can get no volume from it or onto a track thats recording.
On the device menu select "Device Setup"
In the device setup window select vst audio system and then pick your device in the "ASIO Driver" dropdown.
Then in the device menu select "VST Connections"
In the VST COnnections window set up your inputs and outputs.
Then on the tracks you want to record to you have to select which input you want to use. Click the monitor button on the tracks to see the input levels.
Nicely done, TF.
Cubase drives me nuts with their audio set ups. :drunk:
michielper
Replies
4
Views
8K
TalismanRich
TalismanRich
michielper
Replies
3
Views
7K
TalismanRich
TalismanRich
B
Replies
12
Views
2K
Dave Matthews
Dave Matthews
