Dr. Varney
Pimp
When I record stuff, there's a button on the recording software called 'normalize'. When I press it, it makes my recording louder.
But what is normal? Normal to what?
Dr. V
Dr. V
"Normalize" is a generic scientific term meaning adjusting values to some defined standard. What that standard is depends entirely upon the person or people making that decision.When I record stuff, there's a button on the recording software called 'normalize'. When I press it, it makes my recording louder.
The only time I've found normalization to be useful is when you're batch processing a bunch of audio files and you need their peak levels to be uniform.Outside of a laboratory, peak normalization is fairly useless. RMS normalization can be a bit more useful, but still is really a mostly unnecessary tool.
G.
Agreed. If one needs to peak normalize otherwise fairly consistent recordings such as voice transcriptions or something similar where other attributes such as RMS and crest factor are already pretty naturally normalized, batch peak normalization can be helpful. But when those other attributes are all over the map, peak normalization doesn't have a whole lot of use.The only time I've found normalization to be useful is when you're batch processing a bunch of audio files and you need their peak levels to be uniform.
& when it does that it increases everything including noise.
Kind of true; but limiting is really just another flavor of normalization. Instead of saying raise the gain until the highest peak hits 0dB, limiting says raise the gain by an input amount but limit the peaks to the limiter's setting.Actually, the "you must be this tall to ride" analogy would translate more for limiting than normalizing as both are rejection based.
You can't be serious. That's like saying steak is like another flavor of ice cream. There are no bones in ice cream.Kind of true; but limiting is really just another flavor of normalization.
G.
You can't be serious. That's like saying steak is like another flavor of ice cream. There are no bones in ice cream.![]()
I'm as serious as a heart attack.You can't be serious.
That's not normalization, that's generalization.I'm as serious as a heart attack.
Any process that adjusts data values to conform to some standard is a form of normalization. That is in fact what the term "normalize" means. Limiting says that the highest data values cannot exceed some set value, That is a form of normalization.
The problem is not in the definition of the term "normalize", it's in it's incorrectly specific usage within audio editing software.
So kindly put your birch stick away, because I'm not dropping trou.
G.
I'll bet you could go on but it'll still be wrong. Standardizing a sentence and censoring is not normalizing. I am not normalizing when I'm limiting. Converting sample rates and bit depths is not normalizing, it's standardizing. Normalizing is not bringing things into standard by any stretch of the imagination.This BBS performs normalization whenever it changes all caps messages to standard upper/lower case, or whenever it converts forbidden words to all asterisks. It's just normalizing text instead of audio waves.
Any time you convert fractions to their lowest common denominator, you're normalizing the fractions.
Coming back to audio, converting multi-channel audio to mono is a form of normalization. In fact stereo mixdown itself is normalizing the signal to a standard stereophonic signal. Taking WAVs of varying sample rates or bit depths and converting them to a single standard type is a form of normalization as well.
I could go on.
G.
Well so I'm wrongNormalizing is not bringing things into standard by any stretch of the imagination.
but you are stretching it's meaning when used in audio and I think that's in error too.It's not that I'm stretching the meaning, it's that the marketing whizzos at the software companies have crushed and straightjacketed the real meaning into one little tiny specific example of what the term and the process really means.Well so I'm wrongbut you are stretching it's meaning when used in audio and I think that's in error too.
