Acoustic blankets..? Help!
  • Thread starter Thread starter metaljoseph
metaljoseph
metaljoseph
Dedicated Member
Anyone who claims that absorption materials will lower your volume is LYING to you right off the bat.
Your best "bang for buck" for absorption (which is used to make your space sound BETTER, not QUIETER) is rockwool, mineral wool, or semi-rigid fiberglass insulation that's UN-faced and 3 or 4" thick, 3 PCF (Pounds per Cubic Foot) density. It's cheaper and more efficient than ANY foam, it's fireproof, and it'll go further toward making a room sound even than anything else. You can buy or make cloth bags to contain it/beautify it/hang it.
Do a search here for 703, rockwool, fiberglass and any other term mentioned above; there's a ton of discussion here on the subject. Read for a day or two and you should get a good idea of what to do with the stuff once you find it.
Stateside there's a chain called SPI that handles this type of insulation -
http://www.spi-co.com/servicecenterdirectory.cfm
Other similar products from Knauf, Spinglas from JohnsManville, Roxul... Steve
When you consider for just a little more than that price you can buy a whole bale of 703 fiberglass or equal it is clearly not a good deal even if it worked, which I too doubt.
Agreed. Stick with something known. It's also terribly convenient that their link to their 'test data' is broken....
Bryan
bpape said:
It's also terribly convenient that their link to their 'test data' is broken....Bryan
Yeah. I noticed that too.
thaks guys.....I ordered some 703 today from owens corning.
