L
leaningpine
What do you guys think of this mastering job? Just curious to see if anyone's hearing what I'm hearing......
http://plunder.com/03deead8b2
otherwise there is no way to tell what was accomplished by the mastering and what was strictly the product of just the mixing stage.
I might play around with it and put some reverb on the o/h's. I recorded them in my garage with treatment on the walls so it's pretty dead in there. Thanks for the feedback.
I don't want to know how it's mixed..... It sounds good on my system and translates well on other systems, I want to know about how the mastering of the song sounds, it sounds OK to my ears but lacking a little something. I didn't start this thread as a "hows the mix sound" thread, I started it as a "hows the mastering job sound"...... I'm not trying to be rude, and thanks for the opinions on the mix but I want to know how it sounds sonically, to other peoples ears and on their systems.......
in order for anyone to comment on just the mastering effort, you need the unmastered version to compare it to, otherwise there is no way to tell what was accomplished by the mastering and what was strictly the product of just the mixing stage.
Without 'before' and 'after' mastering examples of the recording, they can't judge the results of the mastering process itself.
You can usually tell without listening to the mixdown if something is mastered well, you can hear what frequencies are over or under accentuated or over compression or limiting, at least I can. I just wanted to know what other people thought.....
No you can't.
sure you can. If the end result is good, who cares what was done mastering?.. shoot, that mastering could have been just the fade. If the end result is good, you could assume the mastering was good too.
If there are issues, THEN,you might get confused if it was in mixing or not.
IOW, if I look at a car (as alluded above), I can tell if it was polished good. I don't need to see a dirty car first. I look at the finshed result.
end of that opinion...I'd say the finish was so so... I think there are mix problems that can't be taken care of in mastering, and I say that because I can tell. So, I'd say the mastering was so so... because it didn't perform a miracle![]()
See...when you ask "how's this mastering job?"...it really does require that we hear the "before mastering" in order to comment on the "mastering job".
If you just asked, "how does it sound?"....then that's a different question.
