S
soulsainc
Hi... can you use HUB adapters on a 22-2? I notice they come in 1/4" like the 22-2.
Thanks
Thanks
Honestly? They're no good for the 22-2. You can stick them on it, but don't expect to be able to do anything practical with them.I'm picking up some tape from a local seller today and he has 1/4" HUB adapters he's practically giving away, will it hinder operation to put these on.. just for looks?
Thanks
However, if they're that much a bargain, it's probably work snagging a couple anyway - if you upgrade to a 32 or other deck that can use them down the road, they'll come in handy.
You can not and do not need them. Your deck will except 1,4,5, and 7 inch reels. The adapters like jpmorris stated will not work in your case. Your deck has a reel table with a 3 part hold down key. Yet, the 1/4 inch hub adapters will work on 1/4 inch machines, but only if the deck will except 10 1/2 inch reels. As far as I know, the Teac X-10R is the lowest price consumer deck that will begin to need the adapters. BTW be VERY careful about buying nos or used tape. Check Beck's sticky shed threads.
The first pic is for decks that utilize 10 1/2 inch reels. The second is for the smaller decks that uses the 3 keyed hold downs.
I have a Sony TC-357-4 which was also only designed for 1/4" tape on 7" reels but that didn't stop me from tricking it out with TASCAM 1" hubs!
Cheers!![]()
I have a Sony TC-357-4 which was also only designed for 1/4" tape on 7" reels but that didn't stop me from tricking it out with TASCAM 1" hubs!![]()
Now I'd like to see a pic of 10-1/2" reels on it with 1" tape strung through the tape path. Oh hell, let's just go with 14" reels and be done with it.![]()
