H
hairylarry
Great thread and secret weapons
Hi all,
Thanks for a fun read. I usually hang over in the microphone forum.
Here's my mixing secret. When you've got your mix and you're ready to print turn up the snare a little bit.
Another trick to getting that snare pop right is to sweep your mid range eq between 1000 and 3000 with a little too much eq gain until it really cooks. Then turn down the eq gain to a more reasonable amount but not so you lose the cook.
My secret weapon mics for field recording are the Realistic 1070b omnis. Really great mics and cheap. A spaced pair of omnis is your best bet for making your recording sounding like what you hear. I used to use EV 635s and still do sometime but I usually grab the 1070s first.
Also if you are losing the bass parts on a vocal a compressor will give you bass boost smoother than eq.
And thanks for all your tips and the general discussion. Elvis and the Beatles are great but they both got started by the same guy that inspired me. Carl Perkins. I sang "Blue Suede Shoes" for show and tell in the first grade and I never looked back.
Hairy Larry
Hi all,
Hairy Larry
