Victory Pete
Banned
It sounds as if you have it covered for your style and requirement. If the way you tune works for you and gives acceptable intonation that's the battle won.
The tuning method described in the primer is kind of doing exactly what you describe.
Yes correct. Thats why you see compensated saddles on guitars and why the off set is greater with heavier strings.
Ultimately the aim is to make the best of a compromised system and the two most important considerations are. Does it sound in tune to you and does it play in tune with others. Get that much and you are good to go.
Those compensated nuts are not going to help you at all. A good setup and technique will.
I agree. It has also occurred to me that the greater saddle offset for bigger strings is also due to the fact there is a "theoretical dead point" where the string passes over the saddle. the actual vibrating part of the string doesnt start right at the saddle. The bigger the string the longer this "dead spot" is, requiring more compensation. It is also interesting to note that the angle of the saddles stays consistent until you get to the plain strings, here the saddle is further away from the neck. I believe this is because the plain steel strings are stiffer than its wound counterparts and has longer "dead spots" so it has to be compensated more. It is also interesting to see the remaining saddles follow roughly the same angle. I can usually get an idea if a guitar is misintonated by looking at this stepped angle pattern. Of course you really have to listen and use a tuner.
VP
