Nah...its not bad.
- Remove the head cover (2 screws)
- remove the pinch roller (if ya haven't done so already!!)
- remove the plastic transport escutcheon (the one that goes across the middle of the face of the deck; 4 screws)
- remove the upper metal dress panel (4 screws IIRC 2 on top and 2 on the face? Might be getting confused with the 58...)
With those things off you can easily get to all three solenoids and you can see which if any are sticky. If any of the transport actuations are sluggish its a sign to check for a tacky or gooey solenoid cushion (i.e. lifter actuation, pinch roller, brakes). You can pretty well see how to disassemble the things you need to disassemble to be able to pull the solenoid plunger out of any affected solenoids. Then its just having an old t-shirt and some 91% iso alcohol to clean things up.
It is quite possible you will be just fine but IMHO it wouldn't hurt to have a look inside.
