Foam Traps vs OC703
  • Thread starter Thread starter etanercept
etanercept
etanercept
I am building my bass traps now. The help I have recieved here is immeasurable! Although I'm still a complete idiot when it comes to mixing and mastering, it's good to know I get to play the blame game with the "room" (at least some of it). I am buliding 3 each 24"x48" 4" thick OC703 panels covered in burlap. I want to fill my room corners to the R/L of my monitors as well. Easy enough to make, but I have seen these foam bass traps for corners. Do these absorb as well as the OC703? I like the looks, but I want performance. I want a dead room no matter the sacrifice. You guys are great and you can continue to look forward to more questions till I run out of excuses for bad mixes!:D
Go with the 703. No contest.
Yep...the foam won't do a thing for low end unless you buy the MEGA corner thingies. By then you'd have paid four times what it would cost to make them, and three times what it would cost to buy them.
Frank
703 or Knauf.
You don't want a "dead" room, you want RT60 times below a half-second across the spectrum.
Maybe I shouldn't have asked
703 or Knauf.
1.21 JIGGAWATTS !?! Got any blackhole algorithms you'd like for me to compute?
I want a dead room
No you don't. You want a "flat" room, frequency wise. Especially in the lower frequencies, which foam will not be of any help with. It will probably make it worse, since you'll be killing the high-mids but not the bass.
If you can afford it, Superchunks are the way to go for corners...
http://forum.studiotips.com/viewtopic.php?t=535
