The DP004 is a pretty good machine, but pisses me off by not having a backlight, which makes it really hard to use in clubs, where I do a fair amount of remote recording. The KORG is obsolete- one because it uses Smart Media cards, which max out at 128mb. That results in 90 track-minutes in high resolution, which is 16bit/44.1kHz. That's 45 minutes in stereo. Secondly, it only has one built in mic, so you need an external mic to record in stereo. I finally settled on
Zoom H4n to replace mine after 5 years, which does most of what I want to do, but it is basically a $350 machine. Its predecessor, H4, is a $200 machine, and looks good on paper, but has critical design flaws that prevent me from recommending it to anyone. I think it is a headache in a box. The H4n corrected every one of those design flaws. Thanks for that, Zoom.
  Aside from the backlight issue, the DP004 is a better machine than the Korg Pandora, but it is also a $200 unit, and I was trying to stay within this po' guys budget. The Pandora is also a machine I know very well, and it works. Because it is obsolete, there are a lot of them on the market for very little money. It's a bit of a pain to get the tracks into a computer, because it only exports a finished mix in MP2, which is an uncompressed format. This makes it necessary to mix down in the Pandora, then export a *huge* MP2 file, and then rip it to the format of choice, either CD or MP3. For $200, I'd buy a Zoom H2 or DP004, depending on your needs.The DP004 is a true 4-tracker, and the H2 is, I think, the better stereo remote recorder. For $350, H4n beats all of the above. For the novice recorder with no money, a used Pandora is a great bang-for-buck investment. For an experienced recorder, it's a very cool toy.
  For a while, I have advocated the emerging class of microrecorders for novices on a tight budget. In the beginning, they are a learning tool that gets you up and running right away. As you progress, the newer ones record straight to computer software, and act as a cheap USB interface. As you get deeper into it, it becomes a scratch pad for a recording artist, a travelling headphone amp, a portable remote unit, and an auxiliary oreamp, tuner, metronome, etc. It does the whole thing right out of the box, and never becomes completely useless.-Richie
