R
Rich Smith
Headphones are critical to successful tracking. I recently took the time to run a little test… and reminded myself of some old lessons learned.
Initial playback of a raw analog track is not intended to enjoy how great it sounds. Its purpose is to critically judge and optimize your equipment setup and, later, listen for performance errors. Occasionally you get to factor-in a pleasant anomaly or surprise. But, if you can’t get satisfactory results here, you probably won’t find a satisfactory analog fix later on. There really is no substitute for headphones at this stage. Nothing else can provide the critical focus you need.
Monitoring while recording has a totally different objective and may require different equipment. So does playback during mixdown and mastering where headphones, amps, effects, speakers and multiple opinions all have their place and come into play later on.
For initial track playback, I tested all three(3) sets I have and found that my cheapy Tascam HP-VT1 came out way ahead of my beloved old-school Pioneer SE-205 or Pioneer SE-50's. I never really respected the Tascam’s before because they felt like something playschool made compared to the well-built old Pioneers. The Pioneers felt wonderful like great old shoes and I’ve never been disappointed in their sound quality. But, they almost sounded muddy by comparison. The Tascams had equal bass and were FAR more crisp with much better mid and high range response. (I’d love to test them against my old-fluid filled Koss’s from the 60’s… but alas they’re gone now.)
Running an objective Comparison Tests also reminded me how important it is to plug directly into the recorder for initial track evaluation. Plugging headphones into any downstream amp of reasonable quality will probably smooth-out and “improve” the playback quality. But that isn’t what you need to accomplish at this stage. The objective here is to critically evaluate the raw track(s). You need to listen with the best headphones available to you without trying to compensate for anything. And you need to listen as close to the tape as possible.
Rich Smith
Rich Smith
