T
technoplayer
Recovering Gear-aholic
I am trying to hook up and test some gear I purchased that has balanced inputs and outputs.
The inputs are marked 20K ohm transformer coupled and the outputs are marked 600 ohm.
The pin outs are :
Pin 1: Ground
Pin 2: (-)
Pin3: (+)
Question: can I safely run these to unbalaced ins and out without damaging the equipment?
If so, would I tie pins 2 and 3 together and send these to the tip and the ground to the sleeve or ???
The pin outs are :
Pin 1: Ground
Pin 2: (-)
Pin3: (+)
