I
icystorm
Guest
I am a novice mixer, and I have a question for the pros.
I am mixing (using software only) eight tracks of individual instruments. In order to prevent clipping while achieving the highest possible volume, I turn the tracks on one at a time and adjust the volume, compression, EQ, etc., for each individual track.
Everything is perfect for the individual tracks, but when I add the bass guitar (which has a good volume when it stands alone), it pushes the entire mix over the edge (too loud/hot) which results in clipping. Not a lot; just barely.
So, I went back and reduced the bass guitar volume, added more compression, adjusted the EQ. I tried these steps one at a time and in varying degrees. I have taken the volume so low that it is not perceivable in the final mix, yet that one bass guitar track still pushes the entire mix into the clipping range when I add it. It's driving me bonkers. Any ideas?
I am mixing with Acoustica Mixcraft 4.1x.
As a side note, I can rarely get my songs above the 91-92 dB range without clipping, but I hate using a limiter, because it seems to change the outcome too much. I need more schooling!
Thanks for any advice!
Cheers,
Joseph
Cheers,
Joseph
