Lexicon mx300/ Firewire 1814 s/pdif problem
  • Thread starter Thread starter thepad87
T
thepad87
Hi,
I'm new to this forum but have gotten a lot of good information from it in the past. THANK YOU
I have a firewire 1814 hooked up to a lexicon mx300. I tried to hook up the 1814 out to the mx300 in via s/pdif but no luck. "What?!" :confused:
The Mx300 says it is locked but no audio passes through.
I was wondering if any one else has had a similar problem.
Thanks!
Yes, Everything is hooked up properly. Output to input. The mx300 is seeing the s/pdif connection and is locked but no audio.
I was on the phone with m-audio and lexicon and neither could figure it out.
Are you sure? Clock can travel in both directions... you could be locked with the connections reversed.
You can get locking with the frequencies at different rates.
Check the output frequency of the 1814 matches the input frequency settings (usually a config option 44/48/88/96 on lexicon gear) of the Lexicon.
From the manual:
http://www.lexiconpro.com/Product_Downloads/MX300_v1.pdf
5. S/PDIF Digital In/Out
Digital input accepts 44.1kHz / 48kHz signals. When the S/PDIF digital input is selected
and active, the S/PDIF LED on the front panel lights.
Important: It is recommended that you do not connect any digital device to the MX300’s S/PDIF inputs that transmits at sample rates other than 44.1 kHz or 48 kHz (such as 96kHz). Doing so can cause unpredictable performance. Make sure the device you are connecting to the MX300’s S/PDIF In is set as the Clock Master (if that option is available) and transmitting at a sample rate of 44.1kHz or 48kHz only. As with any other connection, if you need to unplug the S/PDIF cable, it is recommended that you switch to the analog inputs (see Input Source in the System menus) or press the Program Bypass button before disconnecting the cable.
Studio – Digital Setup
S/PDIF Out
S/PDIF In
This setup is ideal if you are using the MX300 as a hardware plug-in in a digital recording
system. This setup requires that you are using an I/O device with S/PDIF In/Out, or a digital mixer with S/PDIF I/O option. The Input Source must be set to Digital, and the Clock Source should be set to Digital in the System menu (described on pages 30-31).
Input Source
The MX300 has both analog and digital inputs. Depending on which inputs you will be using, you need to select between analog or digital audio
sources. The MX300 offers three different input sources to select from: Anlg Mono L (Left), Anlg Stereo, and Digital. Input Source refers to whether you will be using the analog Input pair or the S/PDIF digital input. When only a single analog input is to be used, connect to the analog Input Left input only and select Anlg Mono L as the Input Source. All inputs (analog and digital) can remain connected simultaneously in the event you find yourself switching between using both. Use Knob A to select the appropriate Input Source you will be using
Clock Source
This option allows manual selection of either the internal or external clock source for the MX300. When set to 44.1kHz, the MX300 utilizes an internal clock with a 44.1kHz sample rate. When set to 48kHz, the MX300 utilizes an internal clock with a 48kHz sample rate. When set to Digital, the unit utilizes the S/PDIF input clock source, even if an analog audio source is used. Refer to The MX300 and Digital I/O section on page 12 for more information on using digital audio sources. Use Knob B to select the appropriate Clock Source you will be using.
Digital Out
The MX300 can send unprocessed digital audio out its S/PDIF Digital Output while monitoring processed audio through the analog outputs. This is useful when you want to record a dry performance digitally, but also hear effects processing while you are recording. Note: This feature is only available for signals brought into the MX300 via the analog inputs. It has no effect on signals being received at the S/PDIF In. Digital in/out signals are processed normally regardless of whether the Digital Out settings are set to Dry. To send unprocessed audio out the MX300 digital outputs, use Knob C to set the Digital Out option to Dry.
if it's locked it seems like it should be working... are you sure that audio is being routed to that output??? what prog are you useing???
I'm running Protools m-powered with a firewire 1814 interface. It shows on the interface that it is sending signal.
how about some sorta assignment problem in the lexi??? do you need to tell it to use the sp/dif or does it default to it when it senses the didgi input???
Same kind of issue here.
Just got the MX300
Connecting it to analogue no problem.
Connecting to SP/DIF no problem for the input, it locks and it sees the signal but output is silent.
Switched cables just to be sure, same issue.
What do I select
UMC1820 in logic together with the X32 (aggregated device)
Logic as DAW
Setup 1
Analogue it all works like a charm.
Can insert it into the channel and use wet/dry
Can put it 100% on a buss and send/return to that bus.
Setup 2
Same setup but changing the input/output to the SPDIF.
I see the signal coming in, ping says zero ? and no sound, unless I Lower the wet/dry, no effect but only dry.
I solve it now to put the MX300 on a bus in logic.
Go digital in and analogue out and route that signal to my effects return channels on the X32
Seems to work perfectly but makes printing a bit weird,
Record the wet signal and bounce it together with the dry signal to one track.
