S
steppingonmars
Member
Hi all
Seems like I get myself in the same problem over and over again lately. How do I get the drum OH's to have some life without them sounding like an 1/8" drill bit in the ear drums. This is how I've been recording them lately
- 2 audio technica's at2020's in XY config about 3 feet above the cymbals
- 2/3 of peak on the input of the pre's
- little eq on the OH's other than a high pass around 100hz
- some compression, usually a tape saturation setting or something close to it
- a drum room preset aux send or a small plate
I realize it can be anything causing this harshness, but what are the likely causes. Also the room I have is very dead (ceiling tiles on the walls and cielings and bass traps in the corners with carpet on the floor). So here are the possiblilties I'm thinking of and am wondering where to start
- harsh mics - I do notice when doing vox that these mics are quite harsh around the 2k area
- Room - The drums aren't sounding harsh to my ears in the room, but with all of that deadening is it causing problems when micing them?
- digital recording efx - could this be a factor? How much of a limitation is this?
- don't know what the hell I'm doing - I'm hoping this is the reason more than the room and mics as it's more enjoyable to work on.
Here's some things I was considering
- putting the OH's through reverb with eq to soften the sound
- using a tube pre, (I'd have to buy one)
- using a different mic or even a differnt kind of mic, wondering if anyone's used 57's as OH's and what they sound like
You can hear a sample of the OH's on the "recording live" in this forum
Thanks
Mike
Thanks
Mike
