B
I started this thread in a different section, the realized it probably belongs here.
I've read about a million threads on analog vs digital, but they seem to generally be religious arguments rather than factual. I do not want to start another one. What I do want are some cold hard specs on reel to reel sound quality. SNR, Dynamic range, frequency response, THD and the likes.
We all know the how this works in digital audio, but as far as analog tape goes, I've never seen a spec written. Can somebody please provide this?
Also, the same for vinyl.
(I don't want this to turn into an analog vs digital argument. I just want some real information. The words warm, brittle, sterile and so forth are useless terms. Please don't use them.)
Too many parameters still not measurable or difinable to state the nature of the analogue sounds superiority to digital sound.
To justify my statement:
Give me a specific measurement and definition on:
Attack
Room Definition
Depth
Width
Textural effect
Instrument recognition
Distinction of instruments
Voice naturality
You can continue yourself.
It's not a religion.
It's just beyond sience to explain why the human ear choose analog sound as the best and most natural when equipment and media conditions are present to pursuit the potential.
"dolph"
Not at all. Preoccupation with specs is an early phase people go through in sound engineering/recording. I started that phase when I was 17 and grew out of it before I was 20. There is comfort in thinking that one can quantify everything about sound, but in fact one cannot. Standard specifications as listed in the back of a manual are the tip of the iceberg -- a skeletal representation of the body that is really there. So there are things that the industry can't measure and things they just don't measure or disclose.
Your statement that you've never seen a spec written for analog tape only tells us you aren't familiar with the analog world, which is ok.
The simple fact is that sound is a PURELY ANALOG PHENOMENOM. Analog recorders capture the COMPLETE waveform, albeit in a non-linear fashion due to the properties of magnetic tape. Digital recording has extremely linear characteristics but fails to record the compelte waveform and in fact leaves out large amounts of the information, obviously dependent on the sampling rate.
Let's take a quick example:
Compact Disc Audio reproduces 20-20,000 Hz with a dynamic range of 96dB. Because of the sampling rate of 44.1 kHz, there is a very sharp roll off between 20Khz and 22.5 Khz, because nothing can be reproduced above that point AT ALL. Even worse, if a low-pass filter is not used when recording the original digital tracks (again assuming the 44.1 kHz sampling rate), an Aliasing frequency will be reproduced in the audible range of the digital recording. So if there is a frequency of 23.5 kHz that is present during the recording, it will be reproduced as a 1 khz aliasing frequencty on the recording. Again, filters are in place to prevent this, but my point is everything above 22,500 Hz is missing from the recording INCLUDING THE NATURAL OVERTONES. Obviously everything below 20 Hz is misssing as well.
Now let's tape an analog recorder - I'll use the spec sheet for my Tascam 42B since I have the manual here:
AT 15 IPS: 30Hz - 22kHz +/- 2dB Signal to noise ratio 70 dB
Already we see that the analog unit is not rated to go down to 20 Hz, but only 30...... EXCEPT the analog recorder DOES recording lower frequencies than than... they just are recorded outside the specification of +/- 2dB. The same is true of the higher frequencies in reverse: the analog recorder is still reproducing withing the 2 dB specification at 22kHz where the digital recorder has already been forced to roll off that frequency - to the point where it is likely inaudible. At even higher frequencies, the analog deck will continue to reproduce, albeit at a much reduced level, basically getting quieter and quieter the higher the frequency until the point where it fades out. This closely resembles the way the human ear actually works, which is why people say analog sounds 'better' or whatever word you want to use. All the natural overtones are also present on the tape in some fashion as well.
AK
Does anyone know how the frequency response of vinyl compares for comparision to tape?
"Have you ever noticed, browsing these forums, that the analog only section is so much more supporting and polite than the other sections? I think it's because we really love this stuff, and sharing experiences and information with others is never a hassle, there is no elitism."
thats exactly it man. EXACTLY it. i wish this guy wouldn't mess up the supportive flow with his ignorance.
What it tells you is that the analog frequency response curve can be within spec and simultaneously really not flat at all!
