apl
Stand Up Comity
So why does a guitar need to be strung to cut the nut? The target is a point some distance above a plane defined by the first and second frets, right?
No more than a couple of thousandths above the first fret. You can use a very thing straight edge, but you'll have a hard time getting it as accurate that way.
Light
"Cowards can never be moral."
M.K. Gandhi
If your cutting for an electric with low action the depth of the slot can be the same as the fret hight. On an acoustic with higher action it can even be a gnats cock lower. A good setup is also needed to get it right.
I've described my method here in the past. Basically it involves a pencil with a flat planed to one side so you can draw a fine line on the face of the nut at the fret hight. Then cut just above it. String up and play with the neck relief, action and slot depth until all are just so. It's something you get good at by doing quite a few. Take your time on the first few, you'll get quicker as your confidence and ability grows.
Have you got a pic of that pencil gizmo?
It's just a pencil that has had half of it planed away. Take a block plane or similar and hold it upside down in a vice. Run the pencil over the blade so you are shaving off the whole length keep going till you have half a pencil.
You can then use it by laying it on the first few frets and mark the bridge at the same hight. If your still confused I'll try and remember to take a snap later.
My luthier uses a computer guided laser - seriously he rigged it himself.
For the brass nut he cut for my Bruno he used hand & eye I think.
