apl
Stand Up Comity
I once did a setup like that. It was a lot of work.
It takes me FAR less time than trying to tune with a tuner. When I'm changing strings, once I start tuning I have it in tune in about 20-40 seconds (depending on how close I got when I was winding the strings), and if the guitar is already close it takes me 10-15 seconds. It's just a matter of practice. Once you learn how to do it, it is faster and your guitar sounds much better to boot.
Of course, it helps that we have a tuning fork mounted to a spruce box that amplifies it to an audible level.
Light
"Cowards can never be moral."
M.K. Gandhi
I meant setting intonation by ear using harmonics of adjacent strings, back when I didn't have an electronic tuner.
Is that working well on stage for ya?![]()
Yep, me too. Shall I post that link to the tuning primer I'm always linking too?It works fine. It takes me less time to tune than it does most people who have tuners, and most of the time on stage I'm tuning to a chord anyway, which electronic tuners are completely incapable of doing. As a result, I actually sound in tune on stage - a rare thing indeed. If I really need to, I can tell a story while I'm tuning, but it doesn't usually take that long.
Light
M.K. Gandhi
As gunn pointed out are you setting intonation like this?? Intonation is the process of setting the intervals correctly across the fingerboard so you sound good in all keys. Not exactly "in tune".I meant setting intonation by ear using harmonics of adjacent strings, back when I didn't have an electronic tuner.
Oh and I meant to say...
Gotoh 510's every time here. Unless requested to fit something else. All you fancy locking this and that does exactly nada.![]()
Electronic Tuners are better than a tuning fork.
Do you really mean setting intonation or just tuning?
Well, for intonation, you already know that I use an old strobe tuner.
Light
M.K. Gandhi
No, no, no. Past tense: I did one by ear with a tuning fork once, maybe more than once, I don't remember. It was a pain. Now I use a strobe.
If you say so.Can you also say why so?
I'm afraid not in this case. A tuning fork has vibrates at a given frequency, it's fixed. The only way it changes is if you add or subtract more mass. Those tuners you buy in the shop are horribly inaccurate at times. Some are better than others. A strobe tuner being the best.Computers are like, more accurate and stuff?
You don't need a tuner to set intonation. When you set intonation the guitar can be a half tone sharp or flat, doesn't matter as long as it doesn't alter the setup. Bringing the guitar upto pitch and at 440 and in tune across the fingerboard requires a single accurate reference note. Tuning and intonation are separate things.
Exactly. I used the tuning fork to set the A string and tuned the rest by harmonics. Then I checked the intonation of one string by sounding the harmonic at the 24th (if there was one) while fretted at the 12th, and comparing that to the seventh fret harmonic of the string below. I adjusted the saddle accordingly and tried again.
Here is what all of this means to the guitarist: You must not, at any time, use harmonic tones at the 7th fret as a point of reference (skilled piano tuners could use them because they know how many beats to introduce between 4th and 5th). Harmonic tones at the 7th fret are pure 5ths, while in equal temperament each 5th must be lowered slightly. To tune by harmonics at the 7th fret (as occasionally ill-advised) will make the guitar sound entirely unacceptable on some chord forms.
